70deuce
- 121
- 43
- Franktown, CO
I have had an inop CTIS system since I got the M936A2 a few months ago. Went through the troubleshooting guide in the TM's and found my problem. The wet tank is not building up to more than 70-75 psi. The wet tank never gets up to the CTIS's pressure switch's 85 or so psi so the CTIS system does not activate. The air dryer is purging at 70-75 psi. I had a pressure gauge on the wet tank in place of the pressure switch and it never got above 75 psi with at least 120 psi shown on both primary and secondary air pressure gauges in the cab. When I jump the "A" and "B" pins on the pressure switch harness the CTIS works perfectly. Is this a governor caused thing or the purge valve?? The air dryer seems to be working good just purging early and I understand when the governor unloads the air dryer purges. Governor need adjusting?? As stated though the system air pressure, primary and secondary, is at least 120 psi.
