No Horn
jkelly66
My horn was working no problem than I went out to play with my truck one day and no horn I have cleaned everything I can think of still no luck. Got out the test light have juice going to both wires on the horn under hood and I have juice going to the tip where it comes out in the steering colum I did get the button off by accident when I first bought the truck I am wondering if I might have put some of the pieces back together wrong. Here is a pic of the pieces I have.
jasonjc
287
Gravette Ar.
you said you have juice to both wire going to the horn?? I'm thinking off the top of my head here but one should be hot and one should be ground when you push the button. I think. There is a wire diagram here some where and it will help a lot.
jkelly66
maybe one was going somewhere else I saw a ground as well checked to see if it was kleen it was. I am kinda thinking I might not have the right parts here I have a spring a small round piece and a big one? Maybe I dont have the place inside the button kleen enough to make contact?
