I haven't worked with generators at all. I am only getting 24.4 volts-low at the batteries and on the back of the 60 amp generator. I am assuming the larger battery cable coming from the gen goes to a constant bat pos source when the engine is running. Where does the other smaller pig tail go to? I have 0 volts at the pigtail wire. Is there a circuit breaker somewhere? What else could go wrong? I replaced the gen and same problem! The batteries hydrometer at 1175 to 1200-fair/low. Could this be the problem? Any thing else I am missing?
Thanks guys
Its a M35 multi-fuel turbo. internal 60 amp 28 volt gen. brand new replacement gen.
Thanks guys
