NSN,REF,MFG, part number ordering help
paramedic7831
Thomasville, Georgia- USA
Ok I found a new supplier and was goin to get some prices to some parts on my m35a2. This is the message I sent the guy:
Hello I have a M35a2. I would like a quote on the parts listed below. Thank you
Axle seal X 2 5330-00-891-7826
Axle seal X 2 5330-01-152-2443
Axle seal X 2 5330-00-706-1238
Axle seal X 2 5330-00-075-1764
Head gaskets 5330-01-389-0664
Front wiring harness 2590-01-016-3187
Winch shear pin X 5 5315-00-736-8685
Valve cover gasket X 2 5330-00-885-5723
Will Be shipped to 31792
Again Thank you for your time.
Repp
Ok and here was his response :
those are your NSN numbers witch dont tell me what i need to know.. I need your REF or MFG number found after the NSN number in your TM
All I see as far as numbers are : NSN, SMR CODE, CAGEC, and PART NUMBER
I'm I missing something here?
SCSG-G4
PSVB 3003
3,256
Lexington, South Carolina
Repp,
He's telling you he is not a military supply clerk. He needs the manufacturer's part number to be able to find items. NSN's don't do him any good. If you are looking for deuce parts, you need to download the cross-reference sticky in the deuce forum, which will give you the part numbers that he needs to be able to fill your order.
DHennon
Orlando, Fl
Recommend you call George at White Owl. He is in Kinston, NC. His email is: George Kivett gkivett@whiteowl.com. He is a great guy to deal with. There are other suppliers for sure, but I have found George easy to work with.
emmado22
143
Mid Hudson Valley NY
Any decent MV parts supplier should know what a NSN is and how to XREF it. A MFG's CAGE Code wont do much to help either.
I'd find another supplier.. There are plenty out there.
