OD Work Lights
steelandcanvas
85
Southwestern Idaho
Found a couple of OD work lights on eBay a few months ago I wanted to refurbish and install on the Deuce. Not difficult to do, but since you Guys like pictures so much, I thought I'd share my efforts. The light will turn around 180* for changing a tire at night, I'm going to do the same thing on the passenger side.
73m819
320
gainesville, ga.
the lights were used on the first m series right up to now,,,,, i saw some on a hemtt wrecker . i have a nos set that has the old style plug, thay are the same as the ones on the 819 except the plug
steelandcanvas
85
Southwestern Idaho
Good luck with them but the vibration should be a killer out on the mirror arms. Wayne
Didn't think about the vibration....at low idle they move a little, but smooths out at about 800 RPM, which is idle speed for warming up. I'll re-think my mounting if I start going through alot of lamps. Thanks for the tip.
steelandcanvas
85
Southwestern Idaho
Good luck finding a place on the Deuce that they won't rattle. They must be pretty tuff.
They are 28 volt G.E. lamps specifically made for heavy equipment. I agree Doc, try finding a place that doesn't rattle on a Deuce when the engine's running. I was also thinking about having a canvas bag with a drawstring on the bottom to cover and protect them when not in use. Wow, sometimes I think I have way to much time on my hands.
1,129
No, that's a good idea and I am going ot do the same when I mount mine.
