aebiv
- 0
- 6
- Cali/South Dakota
So, I just picked up my 47k mile M1009 the other day, and everything had been working wonderfully. I bought it straight from auction, so there was no foolery from private parties on the wiring of the rig. The charge indicator always sat well into the green, the batteries were strong and started the truck up right away.
Well, I noticed people had said on here, that if the Gen2 light didn't come on, that the alt wasn't actually charging, so I made a quick trip to NAPA, picked up the bulb, and put it in.
Turned the key, bulb lit up, I smiled, and then I went about my day. Now however, on starting the truck again, the bulb does not illuminate (checked the new bulb, it is fine) my charging gauge sits right in the middle of yellow and green, and when I run the blinker it ticks over to red with every blink. When I turn the headlights on, they turn on nice and bright, but the rest of the gauges die like I turned the truck off.
However, it doesn't move (the gauge) when I apply the brake lights, or turn the heater fan on.
I tested Gen1, and it is putting out a healthy 14.7 volts, and if I did it right, Gen 2 is putting out 27.8.
So am I looking at a short? I've done some reading on here, and although my problem isn't totally unique, I couldn't find anything exactly on it.
Thank you!
Thank you!
