Whiterabbit
- 14
- 18
- Bristol Va.
Been tracking down an overheat issue.
New water pump, old one's seals failed.
New thermostat.
Flushed and cleaned the cooling system a dozen times.
Last issue I thought might be causing the high rpm overheat was slightly loose belts. Nope.
Head torque good. Head gasket good.
What's this----
The rocker arm shaft was slightly rotated!
Low oil flow!! That was it!
Oh, vote for my M151A2 for MV of the month!
MUTTS RULE!!
New thermostat.
What's this----
MUTTS RULE!!
