First of all rsh253, I'll jump on to your thread because we need to get together sometime.
Very similar to your problem so I hope I am not hijacking, I have oil coming from my speedo cable. I think I need to tighten it to the dash panel, but I also think the speedometer adapter that connects to the transfer case is leaking and may be the root of my problems. I put about 1/2 quart of oil on the chassis during my drive home from Jacksonville with the TCase as the source. Now upon closer inspection it looks like the speedo adapter is the culprit, possibly along with a plugged vent. Do you guys think that this is a plugged vent and a bad adapter is to blame for the oil blowing out under the truck and up the cable into the cab? I'll check the vent now, but would the adapter also be bad causing the speedo cable to leak?
Thanks.
Ryan
