Oil pressure high after oil and filter change
benhasajeep
Eddington Maine
Well we (wife) changed the oil and filters yesterday. Wix 51133 filters, Rotella 14-40 T-4 oil. Pressure gauge which was working in normal range before the change. Is now reading 90 psi.
From searching I see the pressure regulator in on the right side of the block near the turbo. But why would it all of a sudden stick / fail after an oil change??
Nomad1
Conway NH
I have had oil leaks start right after changing the oil on engines as it can knock loose dirt and grime that was blocking a leak. also clean oil can flow better. Is the oil pressure really that high or is the gauge suddenly off?Is the oil level correct?
Nomad1
Conway NH
Let us know what you figure out and of coarse if anbody else has any suggestion as far as what might be going on chime in
Merc1973
Sykesville, MD
Mine did the same when I changed from the old pleated paper .gov style to the Metal covered Wix from NAPA. I was thinking its high because there are not many perforations in that outer steel part, restricting oil flow??? It still does reads high to this day, when its warmed up it does lower some.
benhasajeep
Eddington Maine
The filters that came out were the same style, metal outter band around the filter element. I will probably order a oil pressure gauge or two and install them. See what the pressure really is. Also need to verify that the pressure sender is actually a 120psi sender. Since the gauge is 120. But I am away for work at the moment. So, that is on hold.
