old crane - military?
surfdog
Altamont NY
Just bought a crane/manlift at an auction where they were selling a lot of surplus equipment. Anyone know if this was originally military (or if the military used this model/type of crane) ?
Boom extends about 50'. Powered by 6 cyl Chrysler industrial motor. Crab and oblique sttering. 4wd. Haven't found a name plate yet.
I should have some fun with it!!!
1,808
I can think of a couple that came out of the military. PM Floridianson, he has one I believe.
surfdog
Altamont NY
I'll probably sell it after I finish all the barn beam and roof repair and assorted tree work on the farm.... so that will probably only take me the next 10 years!!!!
OSO
Arlington,Wa
That crane is a RO /Stinger. I painted one back in 1983. Has Dodge 1 ton running gear , I had to take the tranny out and replace a keeper kept comming out of gear. Found the clip laying on the bottom of the tranny . Had a vandel punch a couple of holes in the radiator ,cost $300 for a new core ,back in 1983 at an old time repair shop. He was the most reasonable shop around . Our crane was 5 Ton I think about 1975 model.We had a jib for it ,along with a man bucket.:wink:
surfdog
Altamont NY
It is a Broderson RTR-70-1B, 8 ton 45' height at 80 degrees
Looked it over a little closer today and found the data plate and even a manual in the cab!
It used to belong to the National Air and Space Museum in Maryland - I suspect it came out of our local air museum about 5 miles away.
I think it's gonna look real nice in olive drab.
Had a problem with carb icing today when running it for a short time (it is propane powered). It does not have a heat riser. Any suggestions?
surfdog
Altamont NY
I'm going to keep it and use it around the farm. All of a sudden all my friends have jobs they need a crane/manlift for and are asking about it....
How far from Hawthorne FL are you? My brother has a house there and needs some shipping containers stacked on top of each other. Can your little Scamp lift a 40' (empty) container? Do you do little lift jobs like this?
He just recently bought a sweet clean deuce W/W out of Cape Canaveral to drag them around his property and pull a few trees out -- at least that's what he told me - personally I think it was because I had a few deuces up here in NY and he was jealous of my new toys.
m16ty
218
Dickson,TN
As far as the carb icing, Make sure your vaporizer ( the big round thing that regulates the fuel) has coolant running through it to warm the propane. Most of these rigs were dual fuel and could be switched between propane and gas.
You should be able to set containers with this crane. Just don't boom out too far. There should be a load chart in the manual and a plate in the cab. Best I remember these rigs had a 9,000lb line pull so you'll have to go to a two part line to lift anything over 9,000lbs.
