sht2kll
- 0
- 6
- Spring Creek / Nevada
My m1008 started having starting problems about a month ago. The wait light would come on then go out after about 15 seconds, pedal 1/2 way down , and it would fire up then die. After a couple of times of doing this ,it would stay running and would runn normally until the next day, when it would do it again. I decided to change the glow plugs. I put a new set of 60G's in it. when I would turn on the key, wait light comes on and I see a draw on the volt meter. The wait light goes out and it would crank and crank then finally start. The volt meter still stays in the yellow band and the GP relay does not cycle. After a short time, I hear a weak solenoid sound and the voltmeter comes back to the green. That is the least of my problems. I decided to convert it to 12 volts because the starter would not always work. I converted it like some instructions I had found through this site. To Make a long story even longer, I found after the conversion that the GP relay was not actuating the solenoid, so I put a pushbutton switch in. I now have power to the GP side of the solenoid but this thing does not start very well. I am not sure if I am having fuel issues also or if maybe I fried a few GP's in this process.
