Oshkosh Update Bef/Aft Pics (w/819)
No.2Diesel
11
Huntington, NY
Hi
Here are some pics of our late winter project. It has become a very useful addition to the fleet! It can haul and dump a full 10cu.yds. of RCA. (we finally got to do that this weekend.) Now we can move on to futzing with that wrecker.
Here's a little summary of the work performed:
-Removed old 8' Heil dump bed and 40K Braden Winch. (Winch For Sale BTW)
-Removed all non-stock bracketry and other hodge-podge off of truck & frame.
-Raised location of PTO driven Hydraulic pump on. (was hanging way down like a ball sack)
-Repaired and raised location of fuel tank.
-Wire wheeled frame and undercarriage.
-Cut & raised "new" dump bed cap protector 6" to clear cab.
-Placed "new" 10' dump on frame and secured it.
-Welded on 1/2" plate superstructure for towing etc.
-Added new lights, electrical where necessary.
-Removed stock wheel spacers to utiliize rear duals. Bought new Budd studs and nuts
-Dismounted all old tires and wire wheeled all wheels and locking rims.
-Mounted all new General HCT 12.00x20.00 16ply 45" dia. tires max. load is 7780 lbs. each. (now only made in South America) $150 each with tube and flap.
-Relocated step ladder on dump bed. Wire wheeled and sanded everything.
-Painted truck with Magnet Paints. (Brushed on :D ) JD Green and JD Industrial Yellow (painting still to do)
-Hung mudflaps. Had to get the Oshkosh flaps from Fairfield's in VT 8)
-Oh yeah changed all filters and fluids and Brake Air lines.
Enough said. Enjoy the pictures!! fat lady sings
No.2Diesel
11
Huntington, NY
Now for the Before/after pics:
almost forgot: :wink:
-Welded up height extension channels to receive boards on sides and rear
-Welded up all new 4" exhaust with oval muffler to replace rusty 3.5"
-Went to local saw mill and picked up real White Oak 2"x8"s for the bed sides.
Enjoy!! :popcorn:
Plow mount and a few other things need to be painted to continue the color scheme as well as mounting a large swivel pintle and redoing the air lines to the back plate for glad hands.
maddawg308
747
Front Royal, VA
Brushed on paint job!??! What the ???
Well, regardless she looks a lot better than before. You guys had your work cut out for you, and you came through just shiny. :grd:
