Guys can anyone assist please,
I Have an AMG M931A2. Had problems with Alternator over charging and putting ABS light on !!! replaced with new Alternator, ran for 30minutes, all ok, ABS light out ,checked Alternator output reading 27Volts.
Voltage gage showing in green perfect then suddenly volt gage shoots into the red and ABS lightcomes back on. Leave for 2hrs, try again, run for 30 mins then problem reoccurs!
Thought it could be the Control Box - replaced this everything ok or so I thought - ran further 15 minutes and everything started over again. Over Charging Volt Gage in red, batteries starting to boil! Not good.
I have changed the 4 x themal fuses also, checked all earths, cannot think of anything more that could cause this problem.
Question - any one out there had same problem and if so what was the cause of this overcharging down to ?
Look forward to hearing from someone who has experienced this problem before.
