Overflow cluster
montaillou
828
W.WA
The main cluster will contain:
Speedometer
Tachometer (w/hours)
Air psi
Oil psi
Water temp
Pyrometer
high beam indicator
Now that that's out of the way, I am going to be installing an overflow cluster. I know that gauges can be crammed into multi units, but I like a separate gauge for each thing, the more the merrier (a plane cockpit is my inspiration). This is a cluster that I won't look at very often, when I start up, before I shut down, at lights, etc. Many of these gauges will have warnings that can draw my attention if they exceed a parameter.
Below is my latest mock up. It's not exact, just a general idea of where things will go. The grid in the pic is 1". This panel is 30" long x 10" high, and will be mounted above the driver window and tilted down ( / ). My cab has been modified to allow this.
There are lots of items on this panel that wouldn't be in a normal deuce. My deuce is far, far from normal, I prefer to think of it as abnormal.
I have 2 inclinometers and a boat compass that I'm installing elsewhere, in the cab.
I will be building a camper in the back with a sub floor and its own electrical system.
Anyone else think of anything else? This isn't necessarily about need, though I would like gauges to serve an actual function.
The 4 gauges on the left are fuel tanks. The square in the bottom right, are air lockers. I don't need a black water gauge because I won't have a tank for that purpose.
Barrman
1,730
Giddings, Texas
I am also an information junkie. More gauges are better! There might be an app for a tablet or smart phone that will let you have all the things you want without cutting more holes. Aircraft spruce sells similar stuff for aviation uses. Just something to think about.
G744
3,763
Hidden Valley, Az
Looking at a cellphone whilst driving will get you a big ticket...
Can't imagine that is any safer flying a plane.
DG
