Parking brake adjustments/repair?
mudsharkangler
Maryland
I have been having an issue with my parking brake on an M998. It is the later type that uses the rear calipers to set the brake.
I have followed the manuals etc. and I have run out of adjustment, both on the handle and the rod underneath. The brake pads and rotors are well within specs.
Is this something that can be repaired? Could the cables be stretched that much?
Any help would be appreciated!
mudsharkangler
Maryland
Oh, sorry...guess I was not that clear. Thank you for answering.
I have run out of ways to "Tighten" the parking brake system. The handle adjustment is all the way out and the adjustment not on the rod underneath is also at its MAX. The parking brake barely holds now.
