Parking bulb and trans drain question
Ford Mechanic
Edenton, NC
Hey guys I've got 2 really simple questions that I can't seem to find the answers to. I have searched the forum and the TM's especially about the 2nd question.
#1 I have a front parking bulb burned out it's a 2 filament bulb marked ML 623 I assume it's 24 volt. Is this a mil-surplus supplier only bulb? Does anyone have a crossover #? Or where did you get a replacement from? I have taken it to our parts store and one more that deals with big truck parts and they couldn't find one to match.
#2 What size allen wrench does the transmission drain plug take? Mine has a 6 sided hole for the plug instead of the normal 4 sided 1/2 ratchet hole. None of mine are even close and I would prefer to buy the correct on the first time when dealing with Snap On or Cornwell.
Thanks guys in advance,
Mike
two.fiveM35
11
Victoria , Texas
For the bulb, it is 24v, look at Saturn Surplus, Erik's Military Surplus or one of the others. I believe you can just put a ratchet in the the plug and take it out.
Ford Mechanic
Edenton, NC
Thanks for the reply's guys.
So the bulbs a surplus parts dealer item only, thanks I'll just order a few with my next thing of parts.
My trans drain has a 6 sided plug instead of 4, that's why I was asking. Ya'll are useing just a 1/2 breaker bar in it?
1,172
Not all plugs are square drive. Some are 9/16" hex. The least expensive item to use is, a 3/8" all-thread rod coupling. Then use a wrench on it.
The bulb has 2 elements for durability. A less durable replacement bulb can have only one element.
Saturn Surplus has them.
1,125
No. They don't realize that a small # of the trucks out there have a recessed allen drain plug. The majority of the trucks out there have a 1/2" square, but a few have the hex style.
I can't remember what size it is.
nk14zp
17
Columbia Falls Maine
Ditto on the 9/16. My local napa can get me the bulbs but they are costly.
runk
65
Houston, TX
Or McMaster-Carr for the bulbs.
McMaster-Carr
1505k389 or 9527t085
I jammed nuts on a bolt to make a doubled ended bolt, but a coupling nut would have been a better idea, wish this had come up before lunch, I would have added one to my McMaster Carr order this morning...
McMaster-Carr
1,172
I was hoping someone had a NAPA or Carquest type # for it.
Click on the last(of 3 links) I posted in post #9. (links are the yellow words)
All you need to tell anyone is, you need a # 623 bulb. Like when you ask for an 1157 bulb...
