Part ID Help
Warthog
231
OKC, OK
That will be the Mr Fusion unit.
Or it could be the wiper motor and gear.
1,174
Your best bet would be to look at the TMs ending in "P" (PARTS).
Nothing but exploded views and part names and numbers.
If you have eyes, and can read elementary level English, it's usually all you need(for threads/issues) like this one.
ARYankee
33
Benton, AR
Thank you doghead. I guess I was looking in the wrong TM. I was looking in the -34 and of course couldn't find it. At least I wasn't looking in the deuce TMs :)
1,174
quick refresher...
the lower the last number, the more simple the TM.
-10 operators manual(how to drive it)
-20 Unit level fixes(where the truck is used)
-34 the most difficult/technological fixes(a trained mechanic may need this info)
ends in P, exploded parts views and part numbers.
A bonus for CUCVs, the part numbers are usually GM part numbers, easily crossed or found with a google search.
ARYankee
33
Benton, AR
I never really knew that nor did I take the time to figure that out. Now I have learned something else. I appreciate it doghead.
biggestc69
Council Grove KS
If you decide on a new one steer clear of the NAPA ones. I went through two. The first one ran really slow and smoked. The second ones washer motor didnt have enough umph to pump the washer fluid. I used a cheap aftermarket pump on a pushbutton to work around the problem.
