No, LDS pistons have 5 rings.This was from an LDS?
I just did some reading. The wedge-shaped ring & groove is called Keystone. A keystone ring allows cylinder pressure to get behind the ring and forces it against the cylinder wall. It is a common design especially on the top ring. The keystone rings are less likely to form carbon deposits due to the scraping action that takes place asn the ring twists within its groove. They are also less likely to stick.And what about the upper compression ring groves? Are they supposed to be wedge shaped or is that from all the pounding from ignition?
Rick
