- 2,052
- 56
- 48
- Milford / Michigan
Well, I think I have been trying to fight off he realization that I need new piston rings in my M35A2. I have some blow by and it never liked starting when it was cold out. I had the cylinder heads off once before just to put new gaskets on and there was hardly any ridge on the cylinders. The engine has about 1500 hours on it. I think all I really need to change the rings are cylinder head gaskets, oil pan gaskets and piston rings. Is there something else I might be missing or things I should look for when I change the rings? The engine had good oil pressure so I planned on using all the same bearings but maybe replacing the rod bolts if there was a newer or improved bolt out there for this. Any advise would be helpful. I am just not looking forward to tearing the engine apart in the truck to put new rings in it. Its going to be a messy job and I hope I dont pull it apart and realize I need a part and have to wait until it arrives. It would be great if I could have it done in a day. Thank you all.
