jfmrj
- 0
- 0
- Lexington, NC
I'm having problems trying to get my glow plug relay bypass to work. When I took off the wires off the 12v block and put them back, don't ask. When I attached the 12v wire coming from the negative post on the rear battery to the 12v block on the firewall the horn goes off. I took all the wires back off and touch the 12v wire to each wire that went to the block. The horn went off when it touched the one with the two holes on the connector. Any help would be great. If anyone lives near Lexington, NC I could use the help.
