I have rebuilt two of them. The rubber seals in them had gotten deformed by the pressure to the point they were leaking. I cleaned out the old rubber seal pads and cut new ones from some conveyor belting I had. The belting has a woven fiber back and a top surface that is a polymer coat of some kind, very tough. It is overall about 3/16 thick. I glued the new seals in place with a good two-part epoxy. The rebuilt valves have been working for over two years now with no problem. I think the belting is enough tougher than the original rubber seals that it will last longer. For my first attempt at rebuilding these, I tried a softer rubber and it did not last long, a month or so.
When I am done with the trucks for the day, I go to the back, remove the glad hand connection cover, and bleed off the air pressure. This relieves the pressure on the valves which helps prolong the life. When the truck is driven or sitting with the trans in neutral, the valve is normally in the position for forward drive, so when parking the truck with the engine shut down for shorter periods than overnight, I put the trans in reverse so the other side of the valve has pressure on it. In this way, the forward direction poppet of the valve that sees pressure probably 99% of the time is relieved of pressure for the time the truck is sitting and the little used reverse direction poppet gets to share the wear.
Regards Marti
