possible to weld differential in m1009 gov lock
turbinesurgun
Lumberton Mississippi
Is it possible to weld the rear diff in my 1009? apparently i was supposed to add limited slip additive and didnt know it and screwed my limited slip up. Any help, suggestions, and pics would be greatly appreciated
hndrsonj
Senior Chief/Moderator
362
Cheyenne, WY
Why cobble it together? NOS 10 bolts are $295 complete. I even think there is one in the classifieds.
turbinesurgun
Thanks, I will have to check that out. Is that the whole axle or just the gears? Its just used on the farm so i do not want to put a whole lot of money into it, but on the other hand i want it to be reliable.
hndrsonj
362
Cheyenne, WY
Midnight Rider
Sesser, IL
If you had a standard 1009 rear axle, you don't need to add anything to it but regular gear oil. The 1028 was the only one that needed the additive from what I read.
m16ty
211
Dickson,TN
I know the M1008 has some sort of locking diff. I'm not sure about the 09.
To answer your question, yes you can weld it up. You won't like it on pavement, it will eat tires like crazy, and you may break axles.
466Navastar
Buffalo,ny
like m16ty says..... +
you have to weld like you know what youre doing though - otherwise you will have about 5 minutes of the best posi you ever had and then BOOM !......dont even think about it - if you EVER take it off dirt or loose stone.....pavement will make you sorry pretty quick.
acesneights1
21
20
CT
Not to mention the wheel can fall off. You could buy a whole rotted chevy gasser truck for 300$ and cut the diff out...
Look around on Cl. an Older 12 bolt will work too and most of them were 3.08
m16ty
211
Dickson,TN
Only time I ever did it was in demo derby cars. It was a dirty cheap way to have pos. Even in the mud of the ring, I'd still break a axle every now and then.
Other than that, there's no way I'd do it to a vehicle I wasn't fixing to crash.
