Power Bleeding Deuce Brakes
4x4 Forever
Emerald Shellback
I have read over the TMs regarding bleeding the brakes on a deuce using a power bleeder.
The TM suggests using 20-30PSI to do this. I have read several threads on brake bleeding and they suggest using no more than 10PSI.
Kinda curious, which is correct? Or, does it matter?
cranetruck
75
Meadows of Dan, Virginia
Never bothered measuring the pressure, just pump it (insect sprayer version), perhaps ten times. It builds up pressure very fast...BTW, I also us it with kerosene for testing fuel burning heater valves and a few "pumps" get the pressure up to 8 psi in a hurry. I do use a pressure gauge to monitor that job.
Srjeeper
40
NE, Pa.
I do mine between 15 to 20 lbs. and that seems like plenty to me.
As a matter of fact I just did them yesterday in preperation for a show next weekend.
Checked my Oct. 1991 TM 9-2320-361-20 and it recomends charging the bleeder to 20 to 25lbs..
2cents
cattlerepairman
3,279
NORTH (Canada)
Also, do NOT operate the brake pedal while the pressure bleeder is connected and pressurized. I recommend using the pressure bleeder with the truck engine off and the air tanks drained, to avoid accidental brake pedal action.
bryan70546
Lake Charles La
yep must have pics ........any luck with the tires . why dont you just wait till i get home to help you with em you dont need to be fooling with that by yourself.:driver:
