motormayhem
- 6
- 18
- Tucson, AZ
A M1009 uses dextron II fluid for the power steering/brake booster right? Is this just regular power steering fluid?
It's fine. It calls for Dexron II, anything higher (the only option being Dexron III) can be added, and obviously Dexron II can be added, much like DOT3 and DOT4 brake fluids can be mixed, or GL-5 can be used in gearsets calling for GL-4, barring sulfer issues with the GL-5 and synchronizers (depends on blend of GL-5, but that's well outside the realm of this discussion).
