ETN550
- 9
- 0
- Knoxville, TN
Here is one of the little 3kw Pow'r Gards I finished fixing up and reconditioning. I have a few more to do. The next one is going to be desert tan in a black frame. Some interesting things I discovered along the way.
- They make 120 and 240. They carry full load on 120. They do this by having one of the two stator coils oversized to carry full load at 120 all by itself.
- They have a crude capacitor voltage regulator. Voltage depends on speed. So the speed must be set correctly to arrive at the proper voltage.
- The engine has a charging coil that runs the machine and charges the battery. The generator also has an unregulated 12vdc coil that is not used but has output lugs under the control panel. Having a 12vdc system as opposed to 24vdc is a plus for me.
- They have a great inlet air heater "toaster" style grid.
- They have an automatic decompression release so no need for a lever on top.
- They are very smooth compared to everything else. almost no vibration.
- The military manual states they use 0.3 gph at 75% load and will run 9+ hours on 2.78 gallons.
- They do not have a low fuel shutdown so they must be bled if they are run out of furel. A 17, 14, and 10mm wrenchs are required. I have already resigned myself to taking these size wrenches everywhere the gen will go.
- 3,200 watts is about all they will pull. the engine is a tiny 5.5hp 270cc unit.
