DanDan
- 2
- 0
- Cambridge, On. Canada
Hello All:
I just wanted to offer some assistance with regards to what you need to check on your vehicle (any vehicle) before you head out for a ride. There may be some regulatory differences between jurisdictions but here is the enforced standard from CVSA:
LEVEL I North American Standard Inspection – An inspection that includes examination of driver’s license; medical examiner’s certificate and Skill Performance Evaluation (SPE) Certificate (if applicable); alcohol and drugs; driver’s record of duty status as required; hours of service; seat belt; vehicle inspection report(s) (if applicable); brake systems; coupling devices; exhaust systems; frames; fuel systems; lighting devices (headlamps, tail lamps, stop lamps, turn signals and lamps/flags on projecting loads); securement of cargo; steering mechanisms; suspensions; tires; van and open-top trailer bodies; wheels, rims and hubs; windshield wipers; emergency exits and/or electrical cables and systems in engine and battery compartments (buses), and HM/DG requirements as applicable. HM/DG required inspection items will be inspected by certified HM/DG inspectors.
And remember this is the minimum.
Cheers,
Dan.
Cheers,
Dan.
