Problem with Engine stop
deconn
Hamden/Connecticut
I have a Kieser/jeep M35a2 1970, with a White engine, the engine stop won't work. We took it apart and found that it was gummed up, once we cleaned it, it seemed to work better but it doesn't spring back. Anyone know how this thing is supposed to work, and where does that spring loaded plunger fit when you put the cover back on. Thanks Deconn
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
This is the actual fuel shutoff lever. Is this what your talking about? If so, you can pull it out, take it apart and clean it up. Sometimes they get gummed up real bad.
Warthog
232
OKC, OK
If you take it apart, make sure you don't loss the small tab at the end of the rod.
deconn
Hamden/Connecticut
We removed the fuel control rod, but while cleaning it we did loose the tab on the end. Can we replace the tab or the whole rod and where can we find it? Thanks Deconn
Warthog
232
OKC, OK
Contact Gimpyrobb. He may have one.
The truck will not run correctly without the tab on the end of the rod.
