nevrenufhp
- 16
- 0
- Sacramento
I've been digging in to different nozzles, and injector settings(pop pressures) to get these engines to perform and keep EGT down. The ones I have found are not a direct bolt in. All the good ones went in the Ppump equipped engines. The solution lately has been to buy a whole injector, and swap the parts to the old body. That's what I did with member DWC. The original setup is a 4 hole nozzle, and pop pressure(fuel wont spray until it hits this pressure) is around 214BAR. The new ones are for a 300hp Ppumped 8.3, and they are a 5 hole with 300BAR. Yes, the MW pump can run pressures much higher, but this is a comfortable pressure for daily driving. Upon initial testing, idle speed a tad low, slight lopey idle when it's cold, the power was a little less, but it was still on close to stock fuel setting. Once the nuts were backed out: much more responsive, the power was more than before, EGT was not getting over 1200(loaded uphill at 60mph), and only light haze at full power. These were chosen just so we could have a stock replacement style. Still waiting on mpg report.
I have another 2. The biggest is the 480hp marine injectors, which actually are about 360hp in these pumps. You cant even order these nozzles in the aftermarket, complete injector, only from Cummins. The other is a 420hp, which should land in the 340hp range. They are also for a Ppump, so it all has to be swapped over, unless I start getting more 5 Ton cores to work with. They look identical, except the nut on top for the fuel line is a little smaller on the MWpump equipped. It's going to be like a Stage 1,2, and 3. Stock turbo on stage 1. For stage2, I'm looking at an HX50. The stage 3 will need an HX50 for a non-towing rig, or a '55 for a hauler or mud runner.
