PS belt position
1983cucv
I have removed the drivers side alt for reference.
I have a PS pump with a two groove pulley and I'm not sure which groove I should use. The back groove lines up with the smaller crank pulley (rear) and the front groove lines up with the larger (middle) crank pulley. Would the middle (larger) crank pulley spin my PS pump faster than the smaller rear pulley?
Thanks.
1983cucv
Which groove is the correct one to use the smaller or larger one? If I spin my PS pump too fast will I burn it out?
