so I went to use the dump a load of gravel last week.. dump lever was a bit harder than normal to get to fall into the raise gear. once it did, pop bang.. no bed lift. looked under it and saw the shaft from the PTO to the hydraulic pump was laying on the ground. blew a u joint.. took it off to get repaired.
today I wanted to find out why it popped when it had worked fine before. I started the truck and got under to look at the PTO
THINGS OF NOTE
Winch lever was in off position.. winch shaft spinning in time w rear hydraulic shaft. does not stop spinning no matter what ive tried.
dump lever on goes between off and on. no more multi positions for raise, lower, neutral, off.
when dump lever off the winch shaft slows and can be stopped with my hand, but still spins when I let go.
____________________________________________________________________
my initial thought is that something broke inside and somehow locked the winch and hydraulic shafts together.
any ideas, suggestions on tests, anything.. ??
thanks
THINGS OF NOTE
thanks
