pto
covert
iowa
does someone here sell a double ended pto for a deuce traqnsmission. so i can run my winch and also run a rear hydro pump for a dump. thanks in advance
twright
Rockmart Ga. 30153
I have a transfer pto. You will have to make the linkage for it .It comes right out the back of the transfer case.
AEC Retired
m16ty
218
Dickson,TN
A power steering pump is going to be awfully slow on a dump. You could also go with a electric pump but they are too slow for my taste also. Many people here have went with a electric pump and are satisfied though.
I used a transfer case PTO to run my dump. Mainly because that's what I had available at the time.
Do you already have a winch PTO on the truck? If so, all you need is the PTO rear output to go on the PTO you've already got. I was told by a guy a couple of weeks ago that he called Memphis Equipment and they had the rear output for $300. If that's right I think $300 is very reasonable for a rear output.
