PTO
albion
texas
Hello, i just got a duece and want to modify it into a dump bed. The problem is finding a rear facing pto for the trans. I found one at Memphis equipment but it is $1200,used. That seems pretty steep, is there a domestic pto part number that will work on these transmissions, the bolt pattern is standard. Thanks, EXCELLENT SITE. Albion
jwaller
19
Columbia, SC
the dump deuces had rear facing PTO's. keep your eyes open on eby they come up from time to time. you could always just use an electric pump and not have the hassle of PTO's.
Twinpinion
Los Angeles, CA
I have a NOS one. Never used. Rear facing output is single speed, forward facing output is two speed. I don't think I'm gonna use it. Make me an offer.
albion
texas
I'm a nubie, what is NOS? So if i understand correctly this has a forward facing shaft that has 2 speeds and a rear facing shaft that is single speed. Do i have that right? Thanks Albion
sermis
17
Temple, TX
Re: RE: PTO
Is it foward revers in both the front and rear? I am looking at adding a rear winch to my truck.
Capt.Marion
15
Atlanta, GA
RE: Re: RE: PTO
"new old stock" it means it is original production, not new, like from the 70s or what ever, but has never been used. Things that are NOS often arrive covered in cosmoline, still wrapped in original packaging.
1,131
RE: Re: RE: PTO
I have a "dumping" deuce with an elctric pump, as opposed to a PTO driven pump and it works very well, albeit slow.
Also beneficial in that you can raise and dump the bed without having to start the engine.
Twinpinion
Los Angeles, CA
Re: RE: PTO
Then you will likely want the transfer case-mounted PTO.
