Pyrometer
sloryd
Houston TX.
pyrometer
thanks for the info.
One of my truck while at idle will have a steady stream of ver faint black smoke from the exhaust. I can also smell burnt diesel. Sounds like wet stack at idle. Truck runs great with plenty of power.
Do i need to turn down the droop setting alittle?
jasonjc
289
Gravette Ar.
I got mine from Diesel Performance at DieselManor, Inc. - Taking the Mystery out of Diesel Performance™ It's a ISSPRO.com Your home for quality Gauges, Tachometers, Speedometers, and more! .The cheapist way to go , is to order the gauge from dieselmanor then call isspro and get a diod from them to run the gauge on 24v. The frist one I got I odered a resitor for it but that did not work. So I odered a 24v gauge from Dieslmanor that cost alot more for the specail order. It came drop shipped from Isspro with the diode and works great. The next time I will get the gauge fro Dieslmanor and the diode from Isspro. The numbers were scraped off the diode so I don't know what it is.
