- 14,639
- 4,811
- 113
- Buchanan, GA
Just thought I'd share a quick free fix for flopping mirrors on the CUCV. Simply remove the screw at the base of the cover for the mirror mount. Then loosen the two clamp bolts that hold the mirror arm in place. I took a section of tie wrap that I had cut off from a wiring job and shoved it in around the mirror arm and clamp. Then tighten everything back up and replace the cover. Done!
