quick IP replacement question
BobMassive
Chicago, Illinois
Hello. So I needed a new IP. Don't have the means to do myself so brought to my mechanic. Turns out they removed the water pump. Everything I've read about this process doesn't include water pump removal. They didn't say why but said to come in and they'd show me why. At 80 bucks an hour I'm none to pleased. Are they right? What are they going to try and pull on me and how can I explain to them how to do it with the pump on? Any quick response would be greatly appreciated.
Thank you.
olly hondro
521
tucson AZ
I dont know the answer, but can comment that an hour or two labor is the least of your worries. I had the IP changed in my CUCV recently...it was a thousand bucks for a rebuilt one w/ labor. So now that I have replaced the most expensive part of the truck, I may as well fix the little stuff and drive it 8<(
Stonepicker1
86
Coconut Creek, Florida
The TM will tell how it's done. Print the pages out and show the mechanic.
You do not remove the water pump to replace the injector pump. Did they drop something behind the timing cover? Bolt maybe?
Warthog
232
OKC, OK
I bet they dropped one of the three bolts for the IP gear.
Only thing on the front of the engine that needs to be removed is the oil filler neck. That is how you remove the three bolts for the gear.
BobMassive
Chicago, Illinois
Ultimately your right. I was skeptical of even bringing it in as its not a diesel shop but just wanted to be armed with more knowledge before I go try and negotiate. Thanks for the reply.
BobMassive
Chicago, Illinois
Well it looks like the TM actually shows the ip being removed without the water pump or timing cover on though all the forum references say the three ip bolts can be removed through the oil filler hole. I guess next time i'll bring it to someone who works on these engines more regularly. Or do it myself.
V8Astro
StL/MO
I'm an ASE certified auto tech. This situation happens alot. As a customer your best plan is to say that AllData shows 3.6hrs labor to replace the pump. For whatever reason they removed the water pump it should not add any time to the labor you pay. If they dropped a bolt, then tough titty. You labor cost should not be higher than $288 (3.6hrs x $80/hr shop rate).
Be nice. Be smart. You'll come out on top :beer:
BobMassive
Chicago, Illinois
They said they didn't drop anything but preferred to take it off so as to be able to see and mark the timing gear. Plus he said he'd have 10 or so hours into it!!!!! Should've known when he said he owns a powerstroke. All and all they gave me a fair price and gave me a new water pump for a song but man, lesson learned. Thanks for that tip on alldata. Id never heard of that before.
mutt1966
13
Allentown, PA
The timing gears ARE marked and cant change as long as you dont remove the top gear which cant be done with the water pump on, Iam going with tyhe dropped bolt
Asgar
Wallingford, CT
I changed my IP on my 1008, as already said, you just remove the intake manifold, IP lines, oil filler neck then the thee bolts 'inside'. no need to remove the water pump. This was my first time and I never saw a torn down 6.2 before so it was read the manual and dive in.
Mutt1966 / all, do you guys know for a fact that the top gear can not be lifted up enought to get out of time with the bottom gear? I am wondering because I was nervous about that and did not want to find out by triall and error. I almost pulled off the water pump to look at the marks as well because I could not tell for sure I did not lift the top gear and disengage from the bottom gear. I would guess they would engineer the housing to prevent this. I'm sure those of you with more experience would know the anwser to this one. I also was really careful not to drop one of the three bolts.
Another posibility is the got confused as to whether the drive pin goes in the slot or a hole and wanted to look at the timeing marks.
BobMassive
Chicago, Illinois
I saw it with the timing cover off and it did look like the gears could possibly disengage with the cover on. But I was under the impression that as long as you didn't bump or turn the engine with all three bolts out that the gear wasn't going to go anywhere. Better safe than sorry I guess.
cjtroutt
CW2 26 BDE HHC S6
C.G. JMTC MICHIGAN
I remove water pump and front timing cover and automatically replace timing chain and
gears & ballancer and I will replace Water pump just for good measure it just prevent any future failure.
And retime the IP to spec with Timing Meter.
And she ready to go for long time.
As for the harmonic balancer it just save the crank from trashed or broken from bad harmonic balancer do to dry rot in the rubber.:driver:2cents2cents
