- 300
- 391
- 63
- Geographical Center of Virginia
[FONT="]When I received my 2 man HMMWV there was a complete 2 level radio shelf hidden under the crumpled troop carrier cover in the back. The radio shelf feet were still installed between the front seats on top of the tunnel.[/FONT]
[FONT="]My goal was to mount this shelf unit so that I could somewhat easily remove the shelves when I needed to remove the doghouse or put something else in the space the shelf occupies between the front seats. At the same time I wanted it to be hard to steal the HMMWV radio tray, as I plan on putting a bluetooth speaker and military radio (PRC 25/77) on this mount.[/FONT]
[FONT="]The problems are that the standard bolt-in installation isn’t difficult, but it does require the use of tools and provides no security for the radio shelf. So, I snagged a few off-the-shelf parts to secure my Humvee radio shelf while making it easy to install or remove without tools, using just a key to unlock one leg.
Here is what you will need[/FONT]
- 2x .50″ 1/4-20 Knob Screws
- 1x 1-9/16″ Wide Masterlock Padlock
- 1x Wire Lock Pin 3/8 x 2-3/4 (may be cheaper to source locally)
