04mustang
- 8
- 18
- Lumberton/NC
Hi,
I am toying with the idea of installing the 4l80e in my current 6.2/3l80 setup. this truck does have the 242 t case already from that MWO.
I am aware of the drive shaft that need to be changed, shifter, linkages, TCM, etc.
My question is on the rear driveshaft. I already have one PN: 12469284 which is a 12K shaft for use with ECV trucks. Would this shaft be ok in my planned application or would I need PN: 12447113 which is the 10.3K shaft? and would this work with my stock M998 Diff.
Thank you,
Corey
Thank you,
Corey
