rtadams89
- 3
- 18
- Phoenix, AZ
I have a M35A2 w/ winch. I've never used the winch, other than to spool it out a bit and back in enough to know the PTO and cab controls work. I'd now like to remove the winch and give clean it up/rebuild it on my bench. Trying to search Google (or by extension the SS forms) has been tricky as I keep getting hits for rebuilding all other parts of a "M35* w/ winch", instead of rebuilding a M35*'s "winch". So, anyhow, here are my questions/desires fro guidance:
- Removing the winch from tuck: Can I just support the winch with an engine hoist, remove the 6 bolts from each side of the winch that seem to be holding it to the winch supports on the truck, and lift it away -- or do I need to leave the winch attached to the winch supports and remove both from the truck per TM9-2320-361-20?
- Does any vendor sell a "kit" that contains all the seals/o-rings that I should be replacing when rebuilding the winch?
- Anything to look out for when disassembling the winch other than what is covered in TM9-2320-361-34?
