Receiver Hitch Mount
LT67
501
Bowdon, GA
The 86 M1008 will need a rear receiver hitch. The heaviest load it'll have to pull is a tandem axle 20ft trailer with a 5500lb tractor on it. Are Draw-Tite units the best or is there a better option?
LT67
501
Bowdon, GA
Tagging in to see what you end up going with. I could dump the spare tire, but I'd like to keep the pintle.
I'll probably drop the spare tire mount and put a heavy duty Draw-Tite unit in there. My 85 M1008 has one and it works just fine...
chevymike
462
San Diego, CA
Too bad you guys are not local to me. I am going to be pulling off the hitch that was installed on my M1010. Would let it go cheap but not worth trying to ship.
sweetk30
horseheads,ny 14845
x2 on B&W massive quality and they stand behind there products . i have installed a lot of there turn over hitch setups .
not so impressed with the level of fit / finish and overall quality anymore with the other brands listed above .
NWM1008
WA
I installed a draw Tite 41938 and regret it. The 2x2 to tubing where ball & pin slides in is very loose. It rattles constantly and drives me nuts!
fitz
13
Mass
Does anyone have the B&W part # they used?
Were you able to keep the D ring shackle mounts without modifying them?
thanks.
cruzer747
145
California
For your sanity try gluing (sikaflex adhesive or other good void filling adhesive) some stainless shimstock in there. You want a little slop so using the hitch as a clamp put a few layers of masking tape on there when gluing the shim, drill it out where needed (from the other side so you do not delaminate it in the process.
I would say add some metal to the hitch but then you make a fatter than normal hitch.
DIVE DIVE
778
Chesapeake, VA
thanks.
B&W HDRH25122 is what I’m using.
