Recovering vehicle markings
warcow105
Lincoln Park, NJ
Quick question, what's the best way to remove all the black spray paint to recover the original markings? I know acetone will strip it, but will it also strip the markings? And if I do restore it, what are the legalities of driving with the markings?
Thanks,
Mike
diesel583
N E Okla.
I wet sand by hand with 800 grit. Been driving my truck for 10 years with original markings and nobody has said anything, but that's in Oklahoma. Your results may vary
DREDnot
443
Phoenix, AZ
I use fine sand paper, red scotchbrite, steel wool, acetone. Slowly work the layers away. the acetone just cleans away the sanding dust.
Amer-team
32
Centralia/WA
I use 4-0 steel wool, sometimes water for lube and sometimes lacquer thinner. But I like the carb cleaner idea. Hadn't heard that one before.
Wire Fox
161
Indianapolis, Indiana
I never knew carb cleaner can strip paint, I will try that as well. Are the markings painted on with carc as well?
Mike
I think this all depends on the unit that does it...if it's done right, it's CARC. If it was quick and dirty, it's a convenient rattle can. In every surplus vehicle I've seen, the marking have always been obscured​ by simple rattle can, but I have no idea what is common for the actual markings.
Keith_J
1,319
Schertz TX
A mixture of xylene and paint thinner, increasing the xylene until it cuts the obliterating rattle can spray. The required strength varies with the time the rattle can has been on.
Unit markings are almost always done with rattle can. But it has been done thick and had plenty of time to cure so it is more durable to the xylene-paint thinner solvent.
WillWagner
2,704
Monrovia, Ca.
Bobert
9
Des Moines/ Iowa
Mike
Thats true, I've only used carb cleaner on the cheap spray paint they hose over the markings.
I discovered carb cleaner softens paint by accident.
