Bkoyle
- 0
- 0
- Alta Loma, CA
I am in the process of replacing the engine rear main seal. I took the seal holder off, which is alumnium, drove out the old seal and pressed a new seal in. Then I went to remove the old gasket between the block and main seal holder. The gasket would come off. Some small chunks came off, but I can't get the rest off. I can't get a gasket scraper in there because there is not enough room. Do you guys have any sugestions?
Thanks,
Bruce
Thanks,
Bruce
