johnfire6
- 0
- 1
- Spring Lake, MI
my accessory/ ignition switch on my truck is need of replacement, I was curious if I have to use a OEM replacement or can I get away with a standard 2 post 24 volt battery cut off switch? The reason I ask is the OEM replacements seem to be very expensive for what they are and looking at the schematics it appears to me that the stock switch has two incoming hot wires and one out going to the in tank fuel pump and the other to the dash and starter, I guess what I'm asking is can I put both in coming hot lines on one post and the two out going on the other of a standard 24 volt switch, thanks guys
