Replacement low coolant module
bigburb11
Detroit, MI
OK. I'll give'r a try. I thought that the module is exclusive to CUCV's (it's a circuit board with doodads to operate the bulb check on startup and act as relay for low coolant light/sender while ignition is on).
Jersey4x4
Absecon, NJ
What board is for the low coolant light? I replaced mine and it was just a sensor in the radiator and that was it. There is no other parts for it listed in the 20P or the 34P either? I did have a problem with it when I ran just distilled water. It kept saying the coolant was low because there were no minerals in the water yet to make the connection from the pin on the sensor to ground
