Countryboy84
- 4
- 3
- Vallejo, California
My glow plug solenoid had 23 volts run through it . I replaced it and checked my glow plugs. But it's not working. I'm a carpenter not mechanic any advice helps
Unless it is really cold there where you are the truck can still start without the aid of your glow plugs. Did you take them out and bench test them? Did you hook everything back up correctly on the new solenoid?Ur no dang help. This is my only ride so if ur not gonna help then keep ur comments to yourself
That should not happen. Normal failure mode is infinite resistance, so a reading of 0.00 is very strange. How did you measure the resistance? What settings did you use on your meter?No . The glow plugs omh is o.oo. I guess there fried.
Because the glow plug system in the CUCV runs off the 24v side, it goes through the resistor bank on the firewall as I mentioned earlier to step down to 12v through a voltage dividing circuit.Why do you think the GP relay had 23 volts run through it? What is this about a "fire"? I see people throwing out all kinds of information here, but we really don't know what problem you have, so it's hard to give info that applies directly to your problem.
I'm well aware of how it works. I'm not well aware of what he's trying to say, and neither is anybody else. I'm trying to get him to clarify what he's done and what his statements actually mean. They are very ambiguous.
For example, "23 volts running through the GP relay" doesn't really mean anything. Volts don't "run through" anything. He might have measured the top of the GP relay when the GPs were not engaged, and he'd have seen 24v there, and might think it's a problem, when in fact, it's normal. OR, he might have measured 24v at the BOTTOM of the GP relay when the GPs were engaged, which would indicate his GPs are all open. We might assume one or the other, but we don't know.
From what he said, it's impossible to say what's actually happening. It's open to many interpretations, and throwing out "fixes" when we really don't even know what he's saying is not usually very helpful.
Not to be rude (wait that has never stopped me before) but trying to ask for electrical help on a circuit you haven't studied is like asking air traffic control to tell you how to land the plane when both pilots are dead.
Or when the engine is on. Or anytime the GPs are not doing anything.Voltage over the solenoid input (red wire) and output (orange) will be ~24 volts when engine is off.
You said it should be zero, and then you said it should be 12. I find that a bit confusing.This voltage should be 0 when GPs are heating. This voltage should be around 12 measured to ground when GPs are heating.
Measuring over the Red to Orange wires should be ~24 volts except with glow plugs cycling. Red.to orange is zero when cycling.Or when the engine is on. Or anytime the GPs are not doing anything.
It should be ~12v when the GPs are heating.
One of these days I should figure out what the voltage should be for every GP that is open.
