Road Speed
MolderBrown
Prospect Ohio
I am looking to buy a M-37WC, and knowing that their top speed (OEM) is only about 50 to 60 mph , I would like to "adjust" the old darling so as to at least keep up with traffic , and not get run over . I am NOT a mechanic , but I believe I've heard that If I change the ratio of ring and pinion gears in the rear-end , that I would derive more speed .Doing this (or whatever is needed) would cost me a commensurate loss of power , but I'm not gonna be using it as a tractor , so the loss of a little power doesn't matter . Any assistance that anyone might offer would be greatly appreciated . If you want , you can email me at --- molderbrown@gmail.com . Thanks
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
Better pick something else to drive. 45-50 is a realistic top speed, any faster and engine is screaming. Stock brakes are not safe at higher speeds.
These are best for around town, or back country roads, not high speed.
Ferroequinologist
Resident railroad expert
736
Liberty Hill, SC
Can you make an M37 go that fast? Yes. But you will have to change the gearing, put a much better braking system on (people love to make things with more go but forget about the whoa!) and probably swap out the engine as well as the flatheads don't like overreving AT ALL.
It's the nature of the beast. If you want to drive a MV, you have to pretty much forget about keeping up with traffic! Only a few MV's were built and designed to reach, maintain, and come to a stop from modern highway speeds.
Thunder in NWOR
Northwest Oregon
The M37s we had in VietNam would hit the governor at about 46 MPH indicated on speedometer.
If you have ever REALLY NEEDED to stop, 45 is way fast enough for the stock brakes (that are in servicable condition), even with no cargo.
Squirt-Truck
Master Chief
162
Marietta, Georgia
An M-37 over 45 is scary. Even with good stock brakes. They are rated 55 but they scream for mercy at that speed.
Little-Truck likes 40 MPH and even gets some sense of fuel mileage at that speed.
You can change the gears, but where is the additional power going to come from? They struggle with the stock gearing.
