jdeoliveira74
- 2
- 0
- wilmington nc
I know someone modded a shipping crate to start and engine on here searched but couldnt find it...
you have any more pics of your setup nice job.. I will definately do the same may use a grinder thoughI did the sawzall mod on the crate. Looped the cooler lines. 24v jumper to the shutoff solenoid from 2 small batteries. I couldn't get jumper cables to send enough juice to the starter so just wired up 2 batteries with regular battery cable.
looks to be in the block i would think oil pressrenoticed pressure gauge in back of head whats that for??
Oil pressure gauge. If there is an oil filter on it, remove it and dissect it. Sparkly bits would indicate a tear down would be better than a ground hop.noticed pressure gauge in back of head whats that for??
