SAE measurements on 4a032
m139h2otruck
NH
Can someone give me the dimension from the face of the flywheel surface to the face of the bellhousing surface (depth of housing) for the 4a032? Thanks
Trying to matchup an SAE mounted pump so we can directly connect the engine and pump unit. Will be using on water truck to both fill the tank and run the spray heads. With the 24 v starter, can use the on-board power to start pump and since the truck is gas, will just hook up gas feed to engine to the main filter, so no extra batteries or fuel tank.
