Sea Foam?
cucv1833
Lake Charles, LA
Yes I use it some time in my fuel tank.. It seems to work good and its been around a long time. Before my last oil changed I ran some in the oil for a few miles then changed my oil.
Go to the website and follow directions
Heres a few threads on the subject good luck
http://www.steelsoldiers.com/conversations/83603-seafoam-sale-autozone.html?highlight=seafoam
http://www.steelsoldiers.com/cucv/67622-sea-foam-spin-question.html?highlight=seafoam
http://www.steelsoldiers.com/cucv/26701-diesel-additive.html?highlight=sea+foam
Capt Pat
91
Sandusky, Ohio
Sea Foam is really good stuff, I use it in my equipment and the towing company (read marine towing company here) has used it for years in their gas and diesel equipment and also uses it to lay up (pickle) any engines that have sunk and have to be laid up to await the bill being paid for the owner to get it back. Saves thousands of dollars worth of engines annually. They buy it by the drum.
Matt65
Alabama
Good stuff, used it a few times when needed. I read it was on sale at Autozone per the gallon a few days ago here on SS.
GPrez
Mt. Airy, MD
Not in my CUCV yet, but at my last oil change in my company truck the shop added it for free and asked me to let them know if I noticed any difference. It did make a difference in the low end acceleration.
that1028guy
Florissant, Mo
When I did my spin on fuel filter, I filled the filter with 75% sea foam and 25% diesel... Judging by the speed racer smoke screen I'd say I have the cleanest diesel ever! At least for a minute... I love it and use it in all my toys.
M1008driver
Great Falls, Montana
I use it in all my vehicles. My M1008 ran so rough I thought I needed an IP. Not anymore. My Ford always gets the check engine light and needs oxygen sensors. Not anymore after using Seafoam.
2 cans when I have a problem, then I run most of the fuel out before refueling. One can every month after that.
ctmustang
Thomasville-N.C.
I prefer Lucas in all my engines. I use the oil conditioner and the fuel additive. The fuel additive really does clear up the rough running but according to the data sheet and tests it takes away from the lubricity of the diesel which is already low.
TMNT
Canton, Ga
I use Sea Foam liberally in all of my gasoline engines. It works wonders for cleaning out gunked up fuel systems. I don't recall ever using it in one of my diesels, but I'm not sure why I haven't. I do use Lucas in my diesels and always with good results. I've also discovered the power of ATF in diesels. A couple of quarts in a tank of diesel cleaned up my M35's fuel injectors, apparently lubed up some dry seals and stopped some several small fuel leaks, including one on a fuel injector. Your mileage may vary, but my observations have been that a ATF in the fuel is a good thing.
PAm1009
hatboro,PA
its a marine grade 2stroke oil with TC-W3 i have read alot of research about using it in diesel engines and guys love it even in old big rigs. its a ashless non synthetic 2stroke oil which is what you wanna run in a diesel if adding oil as a fuel lubricate. my 1009 is my first diesel my dad told me the trick and have been using it on fill ups for over 2 years and wow what a difference it makes runs much smoother
armytruck63
10
Redlands, CA
Ditto here on the two-stroke oil. I use it in the M35A2 and M1009. It adds lubricity to the ultra-low sulfur diesel fuel we are forced to buy these days.
