Seal sizes
Two Dogs
Conwy Valley, N.Wales, UK
I need to replace the front inner axle seal and the hub seal on my M35A1 but am having difficulty sourcing these parts over here. Please can anyone help with dimensions of these seals so that I can try my local bearing and seal supplier. Any help would be much appreciated as I am getting a bit desperate.
1,177
They are specialy made for the truck, they are not a common "universal" seal. Best to get them from an MV parts retailer.
gringeltaube
Staff Member
2,518
Montevideo/Uruguay
This seal is an unusual one and is a very tight fit. I am betting it will have to be the proper one.
M35 Inner Hub Seal, 10896684 / A1205Z650
:ditto:
Not so the inner one for the axle! Its a stock oil seal, single lip facing inward.
Outer (seat) diam.: 68.3mm
Axle shaft diam: 42.2mm
Seat depht: 13mm, seal height: 12mm - 15mm
PM me if you need exact dimensions for the hub seal, in case you are planing to have them made there.
G.
Two Dogs
Thank you all for your help, it would be easy if I was in the US but we don't have a dealer here in the UK at present. I have tried to contact dealers in mainland Europe but can get no replies to my emails, however a friend in Holland is now attempting to obtain the parts I need.
Two Dogs
:ditto:
G.
Thank you for those dimensions, I will try the local supplier and will PM you if necessary.
