rivercreek
- 1
- 18
- Berryville, VA
The Patient: M35A3. Brief History: Driving down highway at about 50mph having traveled about 25 miles at same speed. Began to smell gear oil about 3 miles from house and started hearing a noise at about the same time. Stopped the truck, underneath covered in gear oil in plane with front pinion seal on rear axle. Drained fluid - app. 1 qt came out, did have some metal flake and magnet was pretty packed. Note: this failure happened in the last 50 miles. Minor seepage at front pinion seal then, normal for this age vehicle in my opinion. All differentials were checked, full and clean 50 miles and 2 weeks ago. No chunks at all were found in drained remaining gear oil - at least small enough to fit through drain hole. Re-filled diff and drove last 3 miles to get her home. Was quiter but still noticeable gear/bearing noise. Laser thermometer read 255 degrees on top of case just behind rear pinion about 10 minutes after shutting her down. Once she finished dripping gear oil and cooled down a bit, I climbed underneath for a closer look and this is what I found. Attached photos of front and rear pinions, also a photo of front pinion of center axle for reference. The input shaft has been driven backwards 1/2" to maybe 5/8". Have not pulled center driveshaft yet to check to see if front pinion nut backed off allowing this shaft to slide back as it did. I'm obviously assuming at this point, but I'd guess the shaft hasn't broken in half since the distances look to be the same on both side. First question: Has anyone ever seen this? 2nd question: How likely is it that there is catastrophic damage already done and how deep? I plan to tear this axle down just for exploration purposes (curiosity) at some point, but I'm on the fence whether to try and fix this one or look for another used axle. Side Note: I use this truck for snow removal. It's contracted to VDOT for the winter, so a quick repair is essential for me. One last question: Are the gear ratio's in all the A3's the same and are they the same ratio as A2 axles? Just trying to determine how broad my parts pool is. Thanks in advance for any insight.
